inderpendant specialist North east if poss.
  • jonnaz
    • Aug 2009
    • 158
    Anyone know of a specialist in the north east. i am willing to go anywhere really but the closer to home the better.
    car will not run right and i have tryed everything.
    thinking of going to mrc but it is miles away.
    any info will be helpful
    cheers
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    what do you want doing?
    i go to durham for the common stuff, and Rob (GT500) in bradford for more specialised
    • jogi730
      • 2335
      I do believe Automark are based around Middlesborough. No persoanl experience, but I do believe Aelred uses them which would be recommendation enough for me.
      HTH.
      Chris
      Audi 90 quattro (Typ 85)
      20v turbo conversion
      • WabTheKing
        • May 2004
        • 2567
        still a bit far, but i am in the north west (manchester end of the m67)
        • rotoryboy
          • May 2004
          • 3281
          JAS11N on here uses a guy that he trusts very local to you. Give him a PM, he works alot but it will be worth it
          HTH
          Mark
          Race Clio RS197
          S2 Coupe ABY (Green) - RIP
          S2 Coupe ABY (Blue) - Sold
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            yes i was referring to the same garage in durham, volksparts is the name.
            • DJones
              • Jun 2005
              • 2020
              Automark, Stokesly. Top man - 01642 714200 does great re mapping to...
              • GT500
                • Jun 2006
                • 2181
                fer cough will! STick to your side of the country!
                Automark is great at mapping unless you want the N75 valve working...
                Happy to help but I'm now in my new workshop in Otley, Leeds. (Not Bradford anymore! Vasilis)
                Rob..
                87 UR 20v ABY
                97 S6 Avant
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  yes sorry about that, it was indeed Oatley
                  how are the arb bushes coming along?
                  • jonnaz
                    • Aug 2009
                    • 158
                    The problem is the engine pulses between 1000 and 1300 rpm only when up to temp runs fine when cold. i tryed everything new sensors isv ect but no luck. ok a few places to consider then.
                    leeds is fine used to be a student there.
                    using electronic boost control so no n75.
                    • anthonys2
                      • 3512
                      I have used a garage called Autobahn in hexham for the last 10 years and they know my S2 like the back of their hand and they are very good - specialists in audi bmw and merc their number is 01434 607854 ask for steve or robbie and tell them i recommended you!!!
                      • WabTheKing
                        • May 2004
                        • 2567
                        Sounds like TPS isn't set right or is faulty, two screws hold it on, with the TB shut you you should hear a click, vagcom should show in measuring blocks the status of the TB aswell
                        • DJones
                          • Jun 2005
                          • 2020
                          True, though he can if you insist map the boost map and leave the N75 in place.
                          He said to me that over the years he has found the N75 to be so unreliable on high power cars that hes happier to manage boost manually.
                          His customers generally live many miles from him and when they complained the car wasn't going as it was!! it was often down to the N75 but with them living so far away he could not verify it, hence decided to use manual boost control which he has found to be more reliable.
                          In terms of protection the ECU has its own boost safety limit protection which will put the car in limp mode if reached + knock sensors look after detonation.
                          Food for thought anyway...
                          • waveydavey
                            • Oct 2004
                            • 289
                            Another vote for Automark from me. Mark is a top bloke and really knows his stuff.
                            David
                            1994 16v Coupe - Sold on and sadly missed
                            1994 S2 Avant - Warmed up a bit
                            1995 A6 Avant - Dag Dag Delight
                            • jonnaz
                              • Aug 2009
                              • 158
                              The TPS was the first thig checked and replaced as i suspected that as the fault.
                              ok thanks guys plenty of food for thought.
