What's my options with this Turbo?
  • ian4455
    • Nov 2010
    • 787
    Advise wanted what options i have with the following -
    cold side
    inducer = 57mm
    exducer = 84.6mm
    hotside K24 no 9
    inducer = 60mm
    exducer = 70mm
    Cold side overall outside diameter of compressor housing is a204mm with a 64mm outlet.
    Any good ? and what would i need for this set-up ?
  • terrybullwon
    • Mar 2006
    • 8782
    What is it some journal bearing turbo?
    Chef
    • ian4455
      • Nov 2010
      • 787
      Hx35
      • terrybullwon
        • Mar 2006
        • 8782
        Errrrr
        Chef
        • terrybullwon
          • Mar 2006
          • 8782
          I would use something else, but your need a whole bunch of parts to make it work well.
          Rods
          Injectors
          Pistons
          Head work
          Intercooler
          Mapping
          Exhaust system
          Manifolds
          Etc
          Chef
          • Billman
            • 4129
            Very nice turbo good for 500+ ps.
            Give us more specs on the turbine housing. Pictures
            Go Holset or Go RS4
            • ian4455
              • Nov 2010
              • 787
              Options
              Same as this..
              • Billman
                • 4129
                not original Holset! Where did you get it from? Show me a picture of the turbine housing (rusty side :-D)
                Go Holset or Go RS4
                • prj
                  • Mar 2010
                  • 6308
                  That's a chinese copy...
                  • ian4455
                    • Nov 2010
                    • 787
                    It looks like this one, but original
                    • Billman
                      • 4129
                      OK, once again till we get the info we want. How many blades does the compressor have? 8 like in the picture? HX35 8 blades with 57mm induce have most of the times 82 exducer on the compressor impeller.
                      What ccm volute does the turbine housing have? Wastegated or non-wastegated? V-Band or not?
                      Go Holset or Go RS4
                      • ian4455
                        • Nov 2010
                        • 787
                        Turbo
                        Ok here's what i mean, wastegate but these can be removed and blanked shut? Cold side is circlip, hotside is held via 4 bolts and two clamping plates.
                        • Billman
                          • 4129
                          Look inside the volute where the turbo bolts to the exhaust manifold. There should be a number. Is it 12 14 or 16?
                          Go Holset or Go RS4
                          • ian4455
                            • Nov 2010
                            • 787
                            It's a number 12.
                            • Billman
                              • 4129
                              I think it can give you good power with spool in 4th and 1 bar pressure at about 3700 rpm.
                              If you map your car carefully then you dont really need stronger parts but.....
                              In order to go with this turbo above 420hp you need bigger injectors, Intercooler would be nice also since the S2 is small for that hp. You need to check if your car has a metal layer HG since many old S2 have paper gaskets.
                              I had an HX40 with a machined K26-6ccm housing with 57/82 compressor impeller and 75/65 turbine impeller. It was linear and fun to drive. Laggier than the RS2 K24-7200 but much bigger and supported more power. Engine back then was stock RS2 with bigger injectors and modified downpipe + VEMS ECU.
                              Go Holset or Go RS4
