Standard A/R for a RS2 Turbo ?
  • ian4455
    • Nov 2010
    • 787
    Is the standard RS2 Turbo 7cm2 = 0.49 A/R
    Also what is the standard Cold side inducer / exducer size ?
  • david
    • Oct 2008
    • 1268
    RS2 cold side
    exducer 65mm
    inducer 46mm
    [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
    RS2 VOLCANO BLACK] soon to be broken to bits
    • ian4455
      • Nov 2010
      • 787
      Wondering what the advantages if any over a standard S2 turbo from a Turbo
      Exhaust 7cm2 = 0.49 A/R
      6 Blade compressor wheel
      Hotside ind 46mm, exd 52mm
      coldside ind 44mm exd 58mm
      Guess this would spool really quick but drop out top end any thoughts anyone ?
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        you are talking about cm or mm ??
        • david
          • Oct 2008
          • 1268
          i think that will be mm rocco
          • ian4455
            • Nov 2010
            • 787
            err yes, i stand corrected.
            • david
              • Oct 2008
              • 1268
              what make of Turbo is this m8?
              • ian4455
                • Nov 2010
                • 787
                Holset, internal wastegate set at 2 Bar.
                • Billman
                  • 4129
                  What turbo is it? Hx25?
                  Rs2 turbo has a 6ccm volute.
                  Seems close to the stock s2 one.
                  Go Holset or Go RS4
                  • ian4455
                    • Nov 2010
                    • 787
                    HE211w close i agree, hotside smaller and 1mm bigger inducer on cold side with only 6 blades.
