Well,everything is as Prj said. ECU doesn't use lambda for some odd reasons, connected or disconnected lambda acts the same and ECU still has same value... Will try to change soft and see if it helps....
Swap to AAN was made summer 2008 but then it ran fine with some other soft till I was offered a new one in January 2009. Lost my bumper in Feb. and started to drive again in July. Shortly after that I got the problem.
Edit: got new soft in Jan. 2010
