I am currently at the beginning of my engine rebuild and have come across a conundrum. I have an ABY to come out and a 7A block and head to strip. I cannot find a diffinitive answer to which oil pump i can use. Can i use the ABY on the 7A block or do i need a 7A pump to maych the bolt patterns on the block.
The plan was to buy an ABY and see what happens as i can get the block re-machined.
Along with the oil pump, what water pump would i need. Once again i was thinking ABY as i plan on high-ish hp when i am done.
Cheers for any help....
Mike
Mike
and aby ones are selling a quite a premium now....
