My 1984 WR quattro now has a AAN 20V engine fitted. The brake assist and Steering rack are unchanged. In it's orginal form I always ran in on ATF.
My question is quite simple, since I now have the URs4/s6 pump for packageing reasons, what is the best fluid to use?
I understand it is ok to use the later mineral fluid from later quattro's (MB/RR) if you flush out the system?
I believe an S6 used something different again?
Obviously my concern is that of ATF eating the S6 power steering pump seals, and also not working as well with the pump.
Think you've got it the wrong way round here.
