Hy!
Somebody knows if is possible to adjust the MPG reading from board computer at Audi V8?
I changed the engine with 20v turbo...the mpg signal wire from ecu to the dash is correct..but the reading is out off adjustment.
Thank you for help!
All the best!
Eugen
on the side of the trip computer in the coupe there are 3 switches you can set 5% 10% or 15% plus or minus, probably the same on the V8 I'd have though
