Am I correct in thinking the big hex bolt that holds the front pulley on is a stretch bolt on the ABY engine and needs to be replaced each time its undone? I purchased a new one and torqued it up then realised I had forgot the washer that goes behind the pulley.
I know the stretch head bolts are okay to use twice, any thoughts on if I can apply the same logic here before I splash out another 16 quid on a new bolt.
