My car still makes a strange noise when it reach 4000rpm, I keep the noise till 5500 rpm then it is gone. Is sounds like the noise when you use a open air filter.
I havent got the plastic air sucking pipe that goes to the front light, at the moment the air is sucked next to the turbo. I know this cant be good, but I am still looking for the part. But I dont think this can cause this sound. Is it possible that the MAF sensor of the Lambda sonde can cause the sound. It also doesnt run smooth when it is in idle.
The car isnt tuned, and runs on 0,65 bar max.
thanks in advance
Erik de Bruijn
thanks in advance
Erik de Bruijn
s, can someone explain this
