VAGCom logging measurements
  • Rusty
    • 18953
    Did some logs earlier but couldn't see anything that looked like boost pressure. Is it on there and can I measure / log it?
    Finally did some IAT logs, it's 8degC outside though so might not be too useful. Car was going like stink though, then I noticed that it was 1020mBar outside
  • mcandmar
    • Apr 2004
    • 5118
    There is no facility to measure boost unfortunately.
    What do your Intake temp numbers look like? Here are mine...
    Test 1: Motorway driving
    Average temp calculated from 30 Minutes of private test track cruising ~85mph, Peak temps measured from private toll booth flat from 2500-6500rpms in 3rd and 4th Gear.
    Run 1: 15 degrees ambient
    17.8 average during steady cruise
    21.7 peak temp during WOT run
    Run 2: 17 degrees ambient
    19.5 average during steady cruise
    23.1 peak temp during WOT run
    Run 3: 20 degrees ambient
    23.5 average during steady cruise
    25.9 peak temp during WOT run
    So in short, motorway driving averages 2-3 degrees above ambient temp, flat out blasts down motorway slip roads averages 6 degrees above ambient temp.
    Overall i am happy with the results, all three tests were different days but the runs were as identical as i can get. And most important the data seems consistent.
    I was going to fit the RS2 intercooler and do the test again but after seeing those results i dont think there is any point. Be curious to see what data you collected
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • prj
      • Mar 2010
      • 6308
      You can't measure boost with VAG-COM.
      But there is SLC DIY which I reviewed some time ago, and I wrote a driver for it, so that it's possible to have values from vag-com on the same graph.
      • Rusty
        • 18953
        Well, sitting still to setup the computer and then at a junction, before gunning it, then a set of traffic lights, WOT in 2nd again, then turn around, wait, WOT 2nd again isn't the best of ways to test but I had a high and low of 28 and 18.2 with an average of 23.4. When mocing things started to get much cooler but it wasn't the best test. I'll need to do some motorway runs when it has some petrol in it fo such things
        Shame that you can't measure boost pressure, seems a bit mad that. Also, the time stamps are just over 1s apart, can that be reduced to a nice 5 or 10 Hz or is that all a bit new skool?
        • Rusty
          • 18953
          Cheers Dimitri, have you got a link to some information on that? I also have a GPS logger than could be made to work, would be grand to put it all together but I'm no programmer...
          • Rusty
            • 18953
            A couple of things that I measured -
            1. I'm only seeing 97.3% throttle angle, is this an issue?
            2. Timing peak measurement was 41.3 BTDC.
            3. |Engine load peaked at 129.5%
            • EspenW
              • Apr 2007
              • 1534
              • Country: Norway
              I have some notes on maximizing sample rates in Newsh's current thread:
              Get some FATS numbers when you folks are out logging!
              1994 80E Avant
              1986 2L Golf 2 on Alcohol
              • Rusty
                • 18953
                Ah. OK. I was logging everything, hence it bneing a bit toss. Will be more selective next time I go for a play
                What is the RPM on a FATS run? Should do a special S2 one as the S4 has a different power delivery. 3k5 to 7k sounds reasonable. It's time For the Advancement of The S2
                • EspenW
                  • Apr 2007
                  • 1534
                  • Country: Norway
                  FATS is 4200 to 6500rpm in 3rd gear.
                  Go WOT at around 2500rpm or so
                  There is something called CAPS for the A4 (shorter gear ratio), but I suggest sticking to FATS as the 6 speed S2/RS2 boxes share the 3rd gear ratio with the B5 RS4.
                  By adding 0.25s to our times, we can compare to vast databases of B5 S4 times, like this: http://nyet.org/fats/?sort=FATS
                  Did you do any 3rd gear logs?
                  1994 80E Avant
                  • prj
                    • Mar 2010
                    • 6308
                    It's because the fuel chip does not know anything about any boost pressure or even a MAP sensor.
                    And all the diagnostics routines are in the fuel chip. They do communicate a bit though...
                    Ignition is spot on, if you just rev it without a gear in.
                    TPS angle I am not sure about.
                    Calculated load is completely useless. If you want to know load, you have to look at group 0.
                    You need a wideband using winlog. Zeitronix, TechEdge or the one I use - SLC DIY.
                    • Rusty
                      • 18953
                      Cheers for that. I'll have another play in due course
