which sort of spark plug socket fits
  • shadquattro
    • 263
    • Home: England Current: Scotland
    just bought 2 socket things to undo the spark plugs the first one the handle started to bend so stopped using it , then got another one to fit on ratchet spanner and extension and it would nt fit down the damn hole ,is there a special tool for this or can any one advise which make of socket spanner does actually fit the b*st*rd car before i go out and buy even more tools.
    Have been advised not to tackle the car with the lump hammer
    nor drive if off beachy head
    Also how easy is it to get the injectors out and how can you tell if it s duff
    skint but fast
  • Graham
    • 1622
    I nearly got my 1/2" drive spark plug socket stuck in the plug bore, the socket started to pick up in the bore as i undone the plug, so i tightened the plug up and using the head of an allen bolt and carefull manouvering i got it out. In the end i used a 3/8" socket set as the sockets are thinner walled and it works a treat.
    HTH
    • auditude
      • 407
      Well, you can't use it to torque them to a specific amount, but you could use the handle end of the oem lug bolt wrench.
      Kenneth
      1990 Coupe quattro
      1991 200q20v x 2
      1985 4ksq 20vt project
      1986 Coupe GT 10vt project
      2006 Honda Ridgeline
      1998 Honda VFR800FI
