Just as I was driving home the car stalled when I went to pull away, I thought it was strange but it restarted and I drove the final mile home, just as I was pulling into my road it conked out and will not start. The engine just spins over and there is no fuel at the spark plug when I checked it and you cannot feel any vibration on the fuel pump when it is cranking.
So far I have tried the following,
12v across fuel pump from battery and it runs
Checked voltage from the fuel pump wire which is around 10v when cranking
The car has also been down on boost recently and boost cutting but this may just be coincidence
Any ideas will be much appreciated
