Cheapest place for Bosch F5DP0R plugs???
  • Audi Parts Guru
    • 1317
    As the title says...........
    Any suggestions??
    Cheapest I've found so far is about £8 per plug
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    where did you find that?
    • TimE-J
      • Jul 2009
      • 1292
      I got mine through work from TPS at just under £40, that was on trade though!
      96 S2 aby Coupe. Rebuild Project
      96 mk3 golf tdi daily.
      • LVrainman
        • Nov 2007
        • 136
        • Country: Latvia
        audiScars
        • spink
          • 4382
          my local corner shop motor factors, £35 per set of 5,may have gone up now due to vat increase
          • BrianSmith_S2
            • Jun 2005
            • 1342
            • Home: Northern Ireland Current: British Antarctic Territory
            Last set of 5 i got from German & Swedish last month were about £10 each with the forum 5% discount
            • JP
              • 1858
              If running stock power buy em as cheap as you can get them. If running a bigger turbo only buy the TPS/Main dealer ones as believe it or not there is two qualities out there and the normal of the shelf ones break, where literally you can hold the ceramic and spin the nut around it.
              UrS6 Stroker + HTA3586 =
              • s2avant
                • 2426
                £43.08 inc VAT for five at TPS at the moment. When the next GPS is on they will drop to around £39 inc VAT.
                Ben
                • Paulgo
                  • Jan 2005
                  • 498
                  Ive not found any cheaper than a tenner and I need a set right now . Don’t you have to be trade to use TPS tho?
                  • s2avant
                    • 2426
                    Officially yes but unless your local TPS is stupid enough to turn away a walk in customer then it shouldn't be a problem. With targets like we've just got most centres will take whatever extra business they can get.
                    Ben
                    • Paulgo
                      • Jan 2005
                      • 498
                      In that case there’s a branch in Byker up here in Newcastle, so I might pay them a visit. Hopefully they wont ask any questions!!
                        Dont worry about that - ask TPS to give YOU some discount - do they want your money or not ?
                        Any TPS I have dealt with give 10% discount without even trying - just mention you are member of this forum, quattroforum, club audi or whatever. The 4 quid saved might buy you enough fuel to get there and back.
                        • LSG
                          • May 2010
                          • 897
                          Maybe we should do a bulk bye of plugs. I,d be intrested to see just how cheep you could get them. I gess a few of the members on here use this bosch plug
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            is it worth registering on the TPS? it has an option as 'other' meaning, other than a garage specialist,etc...
                            • LSG
                              • May 2010
                              • 897
                              plug info motor parts direct £7.15each +vat got to by 20 off euro car parts £6.55+vat got to by 40 off.I don,t no who also could help with prices and maybe could have a ring about.I,d make the calls if that helps but need contact numbers.what do you think?.I gess there would be p&p to add on but shouldn,t be to muchi hope.
