What Do I need next?
  • Starscream
    • Feb 2009
    • 109
    Another Noobie question and yes ive searched the forum....
    My engine will be going for a rebuild soon and ive been given the task of finding all relevant parts, there are many engines in the project section that have been rebuilt but no actual list of parts that are needed.
    So far on the Ordered list are....
    Head Gasket set - Quattro Corner
    Bottom end gasket set - Quattro Corner
    I know there is a lot more that needs to be taken into account but what are these?
    Piston Rings
    Con Rod bearings
    Main Crank bearings
    Anything else that needs or would you change whilst the engine is out?
    Part Numbers would be nice so that i could source them straight from Audi
    Engine will be in the region of 350-400bhp if that changes anything. Thanks
  • willg54
    • Jun 2009
    • 2055
    Valve stem seals in your kit? If not, defo do them
      If you are doing it, do it properly so:
      bottom end gasket set
      head gasket set (with metal head gasket)
      stronger rods
      rings
      rod bearings
      main bearings
      main bolts
      head bolts
      oil pump
      water pump
      crank sprocket & bolt
      block decked
      flywheel skim
      flywheel bolts
      clutch
      bottom end balance
      head skim + extra deck cooling
      valve guides
      possibly new exhaust valves
      valve seat recut
      + probably a few more bits i've forgotten
      • terrybullwon
        • Mar 2006
        • 8782
        stronger rods
        rings
        rod bearings
        main bearings
        main bolts
        head bolts
        oil pump
        water pump
        block decked
        flywheel skim
        flywheel bolts
        clutch
        bottom end balance
        valve guides
        valve seat recut
        Maybe water Jacketing your head for 400hp is alittle much but none the less very effective.
        I would add
        :Rear crank seal
        :Oil check valve
        :Oil Pump drive on the crank Snout
        :New bolts for sump pan
        :Oil Squirters
        :Crank Crack tested
        Chef
        • Starscream
          • Feb 2009
          • 109
          Thanks for the list guys, now the other problem i have is sourcing, seemed ok with 034 Motorsport until i noticed $70 postage for a couple of things.
          So could anyone point me in the right direction for...
          ARP Head studs
          ARP main stud kit
          Is there an Oil Pump rebuild kit available?
          Other small bits such as sump bolts and flywheel bolts ill get from Audi so they should be ok.
            I havent seen a rebuild kit for them, I took mine apart when I had the engine apart to check it over and all was fine
            • keithsw0
              • May 2005
              • 571
              only get head and main studs from 034 as i made this mistake by getting them in uk and they are wrong over here
              the best thing you can do is just do one order from them so work out all the bits you want from them and get it in one hit and ask them to be kind on invoice so you dont pay as much duty
              i got turbo and all sort and it cost me £80 postage so get a list together
              • Starscream
                • Feb 2009
                • 109
                @ greg s - ive seen a lot of pictures with them apart and i thought there was such a kit, when the engine was running mine always had a healthy reading on the gauge so im guessing it would be fine.
                @ keithsw0 - ah right I see, so ill get them off their website asap! With the postage ill have to take the hit, there are many pornographic bits id love from 034 but my account has been blitzed allready
                Piston rings and big end small end bearings are next when ive actually stripped her. Will standard spec bearings do or are the 034 coated ones worth the extra, like ive said im hoping for 450 bhp.
                • V6quattro
                  • Sep 2008
                  • 949
                  Don't take the 034 coated mains. The don't fit
                  1360kg/600Whp Avant 0-200km/h 9sec
                  • chez
                    • Feb 2005
                    • 49
                    Mine fitted fine into RR engine
                    • prj
                      • Mar 2010
                      • 6308
                      This:
                      One of these:
                      For 350-400hp it is kinda waste of money to fit stronger rods.
                      If you are planning to go further later, then it would be a good idea to do it now, rather than tear the engine apart again.
                      But if you are just going to fit 2871/3071, then if you get it tuned properly, so you don't get heavy knock, you won't need stronger rods.
