Well the Bentley diagram from Dave is a big help - the AAN wiring is slightly different with regards fuel pump wiring based on 1st look.
However - assuming the AAN ECU is wired same internally as ABY then I am confident that pin 37 goes to 12V when key is ON. This should see 12V at the black/red wires on the AAN injectors and black/red on the MAF pin 5... Same as ABY except for wire colours.
@prj - go and try it out if you can.
Eventually, I will get over it.
