Coolant warning light!!
  • Si Blythe
    • Jul 2005
    • 346
    I have began to get an intermitant coolant light on my ABY S2. I topped up the coolant at the weekend with an any car anti-freeze (it loses a small amount via the heater matrix). 30 mins after driving the car I got the dash caption, the water bottle wasn't too warm howeverafter stopping for a minute to check it out it cleared after a small "blast".
    When I got back the water bottle was warm (not red hot). My wife has had the caption this morning after the school run (30 mins) and it has now cleared.
    The gauges are all correct with now obvious indications and the car drives fine. If anyone could offer any advice/problem solving it will be greatly appreciated.
    cheers
    Simon
    You might leave the S2 fold every so often - but you'll always come back!
  • Christophski
    • 3632
    Try topping up the brake fluid reservoir (The oblong one next to the water reservoir) too. I get the orange cirlce with Exclamation mark in it flash and beep at me when either one are lower. Top the brake reservoir up over the top of the max mark and it should help.
