Compression test
  • Costash
    • 878
    • Home: Romania Current: United Kingdom
    Compression test
    What compression should I have on cylinders ?I've done a test and I want to know if it is ok or not.The gauge readings are over 10 to 11 in all cylinders ?THX!
  • driftin jo
    • Sep 2007
    • 2222
    its OK
    • Costash
      • 878
      Well that sounds good!!!THX!
        Compression Testing Pressures
        For an AAN the figures are:
        Compression pressures
        New: 9-14 bar (131-203 psi)
        Wear limit: 7.5 bar (109 psi)
        Max. permissible pressure difference between all cylinders: 3 bar (44 psi)
        Check page 42 of 93 in thie AAN engine manual (like Section C in the Bentley) for similar but different figures:
        • Costash
          • 878
          I like to thanks again to UrS4boy for the great info!!!Cheers
