Greetings all, got a funny noise coming from my head after its warmed up.
Recently had a new Bosch Dizzy curtosey of Robert Cockings, timing chain, belt and water pump done as well to cure a very nasty sounding engine, basically sounded like a bag of bolts when warm.
It sounds much better after all above was done but is still ticking quite loudly from one of the cylinders when its warmed up, around 2000rpm and upwards. I suppose it could be a tappet/lifter? I did a bit of reading and another cause mentioned was the manifold gasket. I know the rocker cover is a bit poor but is holding pressure alright so would this be an easy fix? Maybe an oil additive/change?
I gave it a small service last October so I might try putting some fresh oil in to see if it goes away, covered less than 1000 miles since then in it.
I'm not a mega-home DIY mechanic, don't have access to a garage and limited space to store things so doing anything myself is difficult at best. Luckily RC motors is not too bad a drive away from me and there's a good specialist garage down in Christchurch i've been using and they're quite good.
Any thoughts?
Any thoughts?
