Flywheel torque
  • powaw
    • Jul 2009
    • 80
    Flywheel torque
    Hoping that some knows this answer. I have the AAN flywheel from 034 that is aluminum and uses the 7.25 inch tilton clutch. I can't find the torque values for bolts that attach it to the crank. Naturally its the weekend and they are closed. Thanks.
    currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, Koni, 968 m030 bars, full delrin, Audi I5 20VT, VEMS, Tilton, EFI Express, Seimens, Race Technologies
    see the AAN/944 swap at Nina's 20VT
    AAN Flywheel bolt torque info
    Item 9. This is from pg 27/93 of the AAN engine manual pdf at
    • powaw
      • Jul 2009
      • 80
      thanks for that, I have the same manual, but I was thinking that the value may be different since the original is steel and this one is aluminum.
      • martinjs
        • 3205
        I think you should ask 034 what they recommend, it is their product after all.
        • powaw
          • Jul 2009
          • 80
          Yea I know, but I didn't want to wait until Monday. I just figured that someone on here was using the same part. It's not like I don't have other things to do over the weekend it is an engine swap after all. LOL.
