3b engine sound. What do you think?
  • SEGER
    • Dec 2010
    • 30
    • Country: Belgium
    Hello what do guys you think of the way my S2 sounds and in the end you see my bottom pully wobble. Oilpressure is good and it doesnt smoke.
    Looking for upgrades.
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    you have to change this crankshaft pulley¡¡ hurry up¡¡
    it does not sounds bad .... but you will have to checl someday how the cams chain and timing belt were installed...for check.
    wich type of oil are you using?
      That looks very wobbly indeed... repair it ASAP before risking any damage. Could be several things - need to remove carefully and establish the root cause.
      Engine sounds a little rattley too - difficult to tell on camera like that though.
      • SEGER
        • Dec 2010
        • 30
        • Country: Belgium
        Thanks for the reply's. I still got a lot of work to do on the car. It seems it needs to be straightened and then i'm going to do the engine. Lots of $$$$ allready. And i never even drove the car.
          Don't even start that engine again untill you investigate that wobble.
          99% this is what you will find when you change the crank sprocket
            yikes - that one is well munged indeed... it might not be so serious if just the outer pulley bolts have worked loose, but I fully agree with the sentiment above - do NOT run it again until the problem is resolved.
            • rs200
              • May 2009
              • 1398
              • Home: Croatia
              your engine don't run well..
              crank pulley are bad 100% and engine timing is not good. your exhaust valve start to kicking the piston.. beleve me. I know very well that sound.
              when the engine is cold than you don't have that sound. how did engine warm up the sound is louder and louder..
              well:
              1.crank pulley
              2.cam timing
              3.engine timing
              4. if the noise will NOT go away. than some tapets are bad too-change it
              5.if that don't solve the problem.. than you will rebuilt the head.
              good luck
