finally managed to split my recently purchased bottom end and was a little surprised by the state of the crank. The bearing diameters are fine as are the journals. It is the rear crank seal end. There appears to be a small groove in the diameter (see picture)
Is my crank a right off or can i have it blended out and have no real worries??...
use some 800 grit wet and dry paper to clean it up. Then refit new seal about 2 mm further out will then be on a fresh section of cankshaft and still seal perfectly. Thats the only way around it.
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
or don't pres new seal on old place.. don't push it 100% in , 1mm less and they will not be on old place, after 300k km you will have 2 rings around crank..
i have thought about getting it coated with nickel graphite (this stuff is used in aerospace parts) and getting it gorund back to size....might be a little costly but we shall see...
THanks for the tips/help given so far....iti s appreciated...
