I5 crankshaft
  • prosty
    • Jun 2005
    • 1114
    I5 crankshaft
    Hi!
    Is it the same crankshaft in all I5 engines? in AAN / ABY / ADU / 3B I'm pretty sure they are the same, atleast they are interchangeable, but what about the 7a, does that one work with an AAN / ABY etc engine as well?
    And is it the same bore on the main bearings? I'm looking for a good crank shaft and if a 7a one works, then my search gets a bit easier
    /markus
    2004 9-5 aero
    2009 Subaru Legacy Diesel
    1994 Toyota Supra Eurospec 6-spd LHD
    3-4 Audis in parts
    I'm 99% sure the 7A crank is the same Prosty
    • prosty
      • Jun 2005
      • 1114
      Great, let's hope someone can fill in regarding that last % then :-)
      2004 9-5 aero
      3-4 Audis in parts
        haha, if i had the family album at home i would.... but i think form previously checking it is the same part number
          There are 2 different cranks versions IIRC, Newsh or Jogi got caught out as it wasn't very well known
          • Nik0las
            • 1345
            • Country: Bulgaria
            I got one sitting in the basement from AAN if somebody is insterested.
            • jogi730
              • 2335
              Yes I did get caught out some years ago. AAt the time I needed a replacement 20vt crank as I had bent mine.
              IIRC there are two varients of the crank. They differ in the size of the big end bearings. Can't give you any more information, but just so you are aware.
              HTH
              Chris
              Audi 90 quattro (Typ 85)
              20v turbo conversion
              • driftin jo
                • Sep 2007
                • 2222
                If I remember right the early AAN cranks have different size big ends and or possibly mains.
                  I am not saying there aren't "versions", but I found this (below). It *might* help. (Note: the same PN is also the AAN and ADU PN).
                  • prosty
                    • Jun 2005
                    • 1114
                    Yeah I'm looking for a good nick crankshaft , but I guess shipping to me in .se is a b!tch :-)
                    2004 9-5 aero
                    3-4 Audis in parts
                    • prosty
                      • Jun 2005
                      • 1114
                      I don't think this is correct since there are the same p/n on the main cap bearings on AAN and ABY across the years..
                      2004 9-5 aero
                      3-4 Audis in parts
                      • Nik0las
                        • 1345
                        • Country: Bulgaria
                        how heavy is the crankshsft? i guess shipping will be arround 60EUR
                        • jogi730
                          • 2335
                          When my original crank bent, the first replacement I got which came from a 20vt engine definitely had the wrong sized big end journals. I'm not sure what engine it came from (maybe a ur engine - are these different?) but I still have that particular crank in my garage as it could not be used. The 2nd one I got was fine and is still in use now. It may be an unlikely occurence to get one that doesn't fit, but be aware that this could happen!
                          • quattro87
                            • Nov 2008
                            • 12
                            I believe all of the 20v engines, including the 7a, are the same crank. The Wx/Wr in the urq and the MC engines have different cranks with the difference being the big end journals. The mains are the same across the board. I am running a 7a crank in an MC block right now.
                            • prosty
                              • Jun 2005
                              • 1114
                              jogi: could the crank been machined? That may be the case. The blocks are all the same and I find it hard to believe that vag changed crankshaft size for just one model with the same base design with the engine and head and all other components surrounding it.. but then again, vag is vag
                              2004 9-5 aero
                              3-4 Audis in parts
