Being in the process of slowly building up a separate cyl head( thanks spink), i am trying to source some parts for it. I am going to use stock valves and replace the hydro lifters with new ones. BUT i dont want to use the same springs,as they have done 200K kms, and as a precaution i prefer to replace them. Same with the retainers.
I know that every supplier of springs say that the uprated ones are good for higher revving engines. What are their cons though, and would they be required if you are not revving much past 7300rpm anyway?
ON the other hand, where can one find OEM springs( other than stealers)?
Finally, similar question regarding retainers. Do we need titanium ones? if so, why?
If not, where can one find OEM new retainers other than stealers?
0-200km/h 9sec
