ABY windage tray in sump
  • gordon c
    • 81
    hi all.
    recently starting back with my S2 restoration after a couple of years and i'm in the process of rebuilding the engine.
    i cant remember if there is a plastic windage tray bolted to the inside of the sump, there seems to be 4 threaded holes in the sump that would suggest that there should be, but i can't find the plastic part in the garage anywhere even though all the parts from the car are all organised on shelves.
    if anyone could help or have pictures of what should be there that would be great.
    car is a `93 ABY coupe.
    Your ABY should have a windage tray, shown as item 14A in the diagram below. The PN is the same for the 3B, AAN, ABY and RS2 ADU. Somehow it is different than the 7A windage tray.
    • SteveH
      • 4460
      The windage tray is made from sheet steel, not plastic. Perhaps you have overlooked it whilst searching for a plastic component?
      91 Modded 3B
      14 A6 Avant Black Edition
      • AndyP
        • 6049
        There is a plastic baffle in the sump that bolts to the 4off threaded boss's you refer to, can just be seen in this pic, it's the part with the 'Audibits' sticker on
        http://cgi.ebay.co.uk/AUDI-2-3-20V-7...item35b03f8678
        • gordon c
          • 81
          thanks for the diagram URS4boy, i have the metal windage tray (item 14a) ready to go on. it was the plastic baffle that andyp has mentioned that i cant seem to find (thats what i was meaning when i said windage tray, my bad)
          the more i see the picture of that plastic baffle i honestly dont think it was fitted to my sump when i stripped down the engine, do all S2's have it?
          • V6quattro
            • Sep 2008
            • 949
            My ABY doesn't have a plastic windage tray. Only a metal one.
            1360kg/600Whp Avant 0-200km/h 9sec
            • gordon c
              • 81
              so did it not have a plastic baffle fitted onto the sump?
              i'm hoping this is the case because i was 99% sure that i never had it, just wanted a second opinion before i built everything back up
              • SteveH
                • 4460
                My 3B didn't have the plastic baffle fitted when I stripped it down a few years back.
                91 Modded 3B
                • V6quattro
                  • Sep 2008
                  • 949
                  No it didn't have a plastic blaffle.
                  • JariP
                    • 192
                    The plastic baffle is a 7A part, it's not in 3B or ABY.
                      Ah HA!! Je comprends. Ich verstehe. Itse käsittää.
                      The 034103623A metal windage tray ("restrictor") that the 3B, AAN, ABY and ADU got is different than the plastic 034103623 "restrictor" 7A got. Thanks
                      • gordon c
                        • 81
                        thanks for the help people, much appreciated
