Hey there folks, I'm currently doing a top end rebuild on my 80 2.8 V6 quattro and am having abit of an issue and could do with some advice if poss...
I'm currently trying to remove both cylinder heads which is proving to be a PITA....The dipstick tube runs through a small hole in the exhaust manifold....I can't workout how to remove the head because the dipstick tube has a 'V' shape bracket on the end of it (which secures the tube to the head) which is about 2cm larger than the hole in the exhaust manifold....so...WTF
There is No mention of what you do on 12v.org or other articles...but does IT mention it in the Bentley Manual??
Also the water pipe on the right side of the right cylinder head stops you from being able to withdraw this cylinder head also......this pipe is the one that goes from the thermostat hole to both cylinder heads to which it wraps around the right cylinder head to connect up to the Radiator. Does this pipe mearly pull out from the thermostat hole or is it permantly fixed??
Any advice would be appreciated....It's taken me a couple hours to try and work it out before it got dark.....I should be doing the VSOS right about now..
There is No mention of what you do on 12v.org or other articles...but does IT mention it in the Bentley Manual?? Also the water pipe on the right side of the right cylinder head stops you from being able to withdraw this cylinder head also......this pipe is the one that goes from the thermostat hole to both cylinder heads to which it wraps around the right cylinder head to connect up to the Radiator. Does this pipe mearly pull out from the thermostat hole or is it permantly fixed??
. Is it quite easy to re-seat it back in?
