afterrun pump starts on cold engine ??
  • amatør
    • Jun 2009
    • 20
    • Home: Norway Current: United States
    Hello.
    My After run pump starts when I turn the on ignition !!
    and my fuelpump keeps running when only ignition on ???
    Anyone know why ?
    Thanks for all answers!!
    Originally posted by amatør
    Hello. My After run pump starts when I turn the on ignition !!
    and my fuelpump keeps running when only ignition on ??? Anyone know why ? Thanks for all answers!!
    You don't mention which car you have 3B S2, ABY S2, AAN UrS4/6 or RS2. All I know is that is definitely not right for an AAN UrS4/S6, as explained here for the after-run pump:
    and here the AAN fuel pump (I think B3/B4 fuel pumps might power up with the ignition on):
    • martinjs
      • 3205
      It should run for a few seconds when u turn ignition on.
        Which "it"? The fuel pump or the after-run pump?
        For the AAN, the answer is neither should run with just the ignition turned on. The B3/B4 S2/RS2 *might* be different for the fuel pump but the after-run pump should not run except in "after-run" ignition off, coolant temp 110C, situations.
        • martinjs
          • 3205
          After-run pump. Havent noticed/checked on my AAN but on an S2 it definately should 'purge' for a few seconds.
          • DJones
            • Jun 2005
            • 2020
            Whilst mine is no longer in an URS4 it has the loom etc, wired as per the original wiring and the after run pump primes when the ignition is turned on and thereafter only works when the appropriate temps are reached...
            I have seen three others, whilst still in a URS4 do the same...
            • martinjs
              • 3205
              Originally posted by DJones
              Whilst mine is no longer in an URS4 it has the loom etc, wired as per the original wiring and the after run pump primes when the ignition is turned on and thereafter only works when the appropriate temps are reached......
              That is how it should be afaik.
                Hmm.... I guess I am learning something new.
                I will have to check. I have never noticed mine coming on except after a good run in the summer.
                • martinjs
                  • 3205
                  We should do a poll. Is your after-run system working correctly? my bet is 75% are not.
                  • pixsaudisex2
                    • Sep 2004
                    • 3110
                    89% plus for me.
                    • veneto rs2
                      • Jun 2006
                      • 1022
                      • Country: Veneto
                      Quote
                      Same on the ADU engine
                      http://www.audisportclub.com/
