ur s4 no spark
  • RoadKill
    • Dec 2004
    • 567
    ur s4 no spark
    no spark no out put to the amp's , so im gessing its the senser in side the cam cuver ? hall sender?
    cant get vag-com to work on it to pull codes but it works on my sis's vw polo
    service tec @ East Kent Audi
    S2 ABY
    B8.5 A4
    AAN Coil and Ignition Info
    This post and its internal hyperlinks should help you:
    AAN coil and ignition info:
    • RoadKill
      • Dec 2004
      • 567
      stoped the car to fill the tank and would not restart , sounds like the hall sender thants for the link
      S2 ABY
      B8.5 A4
      • prj
        • Mar 2010
        • 6308
        Can't get vag-com to work huh...
        If you turn on the ignition and view boost on the dash, what does it show?
        • RoadKill
          • Dec 2004
          • 567
          its not my car so cant go look right now i will be haing a look at it at the weekend
          S2 ABY
          B8.5 A4
          • pixsaudisex2
            • Sep 2004
            • 3110
            I had one like this the fuse haad blown by the ecu. Turned out to be a faulty coil pack. blowing the fuse.
              Does sound like the Hall sender. If you don't have access to VAG-com to confirm, then it is possible to blink out the codes using this procedure:
              You will be looking for a 2113 code.
              If it is the Hall Sender, you can follow this procedure to replace it:
              More info about the UrS Hall Sender (G40 Cam Position Sender) is available here:
              It will all be fine.
              Eventually
              • prj
                • Mar 2010
                • 6308
                If he can't connect via VAG-COM it's the fuse by ECU, not the Hall Sender...
                • martinjs
                  • 3205
                  Yes, ive had this before, check the fuse first.
                  • RoadKill
                    • Dec 2004
                    • 567
                    cant get vag-com to work on the white and black plag only seem to work on the big one , i will blink codes at the weekend , not bad the car has done 200k and ran rs2 turbo for some of it still pulls like a train to
                    S2 ABY
                    B8.5 A4
                      I presume this can be confirmed by turning the ignition key to "ON" (not "Start") and checking for the CEL/MIL light. No light, ECU has no power = fuse is blown.
                      • RoadKill
                        • Dec 2004
                        • 567
                        there all good his had it at a local workshop but they could not work out what was up with it , they did not know you could pull codes so started chaging stuff , the rong stuff speed sencers in the gear box LMAO like thats going to tell it when to fire , they have had the car for 12 weeks , hoping to fix it there and drive it off rubbing there nose's in it!
                        S2 ABY
                        B8.5 A4
                        • prj
                          • Mar 2010
                          • 6308
                          Not all cars have a CEL light
                          But yes, other way is to check the MAP readout on the dash, if that's stuck at 0.2 the ECU is not getting any power.
                            I will be totally 100% shocked that an UrS-car (at least C4 UrS4/S6s) don't have a CEL/MIL.
                            Note: not all UrS-cars have a MAP readout in the dash.
                            • spink
                              • 4382
                              A very early s4 avant i got the other day is the only S car i have ever owned or known of in the UK to have a cel light,maybe it was something north american cars have as standard?as every other s2/4/6 i have had has never had one
