Hi. I have a strange problem with my S6 in that its not starting on all cylinders. I have upgraded to the 1.8 t coils so Im thinking the problem is elsewhere.
The problem clears after about 15 seconds or so, I usually hold the rpm’s at 1500-2000 until it fires on all 5 and it runs fine after that. It pulls perfectly under load and WOT.
Plugs are good and both temperature sensors were just replaced as part of my troubleshooting.
The lambda sensor was changed about 20k ago so that should be ok.
Starts no problem when hot.
I notice some very slight missing and minor variations at tickover, but its got 180k miles up so I have to give some tolerance for that.
Not burning oil and the emissions passed the test recently no problem.
Im thinking worn injectors?
Anyone got any suggestions???
