Yes, it was Paul. I guess the only way to do it correctly is on a rolling road as it is only a single seater.
The MAP sensor is stock and may be damaged by the high boost, but the ECU has not raised a fault code to confirm this. I know you have some ones that allow higher boost. Maybe it would be best to solder one of those in.
