Here you go - seems like most TPS centres cant find it!
Plug = 893971974
Gold plated pins = 000979227EA - only in 2.5mm
Unplated pins = 000979135E - 1mm
Thanks for the pin PNs. The people at the TPS centres need to learn to look in the MG 9 harnesses, e.g. engine bay harnesses, to find these connectors. Often the matching pair will be found in the EL "model" category.
In any event, I have added your pin PNs to my MFTS post:
