i'm from Portugal, my name is Mike, 24 years old and i recently bought my first quattro an Audi S2 1992 code: 3B...
i already bought KW v3 suspension; D2 racing brakes 356mm 8pot;
and my next step is the engine,i already have some pistons and rods in mind but i don't know about cankshaft...
so my question is, how many hp OEM crankshaft stand??
The OEM crank is one of the few bits that dont need to be upgraded, as long as you have it balanced and check that the bearing clearances are still with in spec when you rebuild the engine it will be fine. Some have done over 800hp on the oem crank.
You could get it knife edged if you want to reduce weight and disturbance in the sump.
All depends on how much money you have to spend but the crank should be fine.
P.s. your English is fine, they are only joking..
tanks S2_bo,
800hp is over my expectations, i'll be very happy with 500/550 whp....so the OEM crank should be fine.
95.5m is a 2.5 litre diesel crankshaft. Search for Jamo and AndyP on here, they have strokers. RWD19T is building one also, and there will loads more...
by the way & don't worry, your English is a lot better than my Portugese
ok, i will try to talk with them....
if you want i can teach you portuguese ....but it's more difficult to learn portuguese than english....(should be funny) eheh
where can i buy this cranshaft 95.5mm?
how many hp this crankshaft can handle?same as OEM?
tanks
95.5mm is the diesel crank. All I5 diesels have it. Also some 2.5 petrol engines. If building a stroker you can use both crank and block from diesel. Search this forum for stroker and there are a lot of threads about the subject.
