Cam cover has come off tonight and on close inspection there seems to be some pitting on the exhaust cam lobes and on a couple of followers.
Can you give me your opinion on this..should i swap? My intuition says change. if its already started to wear, they're only going to get worse.
If i do change, whats the best route? standard, 7a or RS2? Inlet looks fine by the way...so im guessing 7a exhaust.
