audi s2 fault codes....
00525 - O2 sensor - voltage low -g39
i have fitted a new lamba sensor and this code still shows
00537 - oxygen sensor control
as above i have fitted a new lamba sensor but fault code still shows
01262 - wastegate bypass regulator - n75
member gt500 gave me a brand new n75 valve and this fault code still shows
00533 - idle air control regulator
what do i need to do to cure these codes? thanks in advance
TDIBRETT :-)
TDIBRETT :-)
