Boost leak?
  • Dobby84
    • Feb 2011
    • 1169
    I was thinking of something like this (not an Audi but you get the idea) where the boost is taken from the manifold so its reading the pressure into the head rather than from the Turbo. Suppose you could have one from each so you can see any difference!?!
    • prj
      • Mar 2010
      • 6308
      http://i92.photobucket.com/albums/l2...0220091009.jpg
      There is no difference at full throttle whether you take the pressure at the IM or at the Turbo unless your intercooler is clogged.
      Trying to take the pressure from the same hose that goes to the N75 valve is a very, very bad idea, because if that goes wrong you'll need a new engine.
      Seriously.
      Pull codes, pressurize intake. If you can't do that, contact someone who can.
      • Dobby84
        • Feb 2011
        • 1169
        Thats good to know. Ill double check where the previous owner has installed it just to make sure. Where/ how would you suggest to install it?
        • prj
          • Mar 2010
          • 6308
          I can tell you where not to install it:
          Feed that is connected to the FPR, preferrably also not the feed that is connected to ecu, although everyone does this.
          • Dobby84
            • Feb 2011
            • 1169
            Cheers buddy! Ill add it to the increasing list I now how. lol
