ECU uk repair
  • QuattroFever
    • May 2006
    • 1360
    ECU uk repair
    Have a blown 259 chip.
    Anyone have any contacts to diagnose and repair a vems ecu in the uk.
    Paying £80 for postage everytime is getting real old, real quick.
    Thanks in advance.
    Volcano ABY coupe
    Ant
    £80 postage to Hungary? use interparcel or parcel2go
    Contact Fatbob aka Rob who is mr vems.co.uk
    • QuattroFever
      • May 2006
      • 1360
      Worked out nigh on 40 each way insured. Royal mail
      Will look into those.
      Spoke to rob off the vems forum and he pointed me in the direction of a guy called sprocket.
      Msgd him but no reply yet. His post says he will help with repairs but he's only a hobbiest so can't guarantee anything.
      Have to wait and see if he can test them as well.
      Volcano ABY coupe
      Ant
        Holy moly just checked and they've put the prices right up to Hungary recently, last year cost about £15
        Even so looking £25-30 send it out of UK but I know it cost a lot less to send from Hungary to UK
        pm Pnanassy he shipped mine out and it didn't cost that much
          Originally posted by QuattroFever
          Have a blown 259 chip. Anyone have any contacts to diagnose and repair a vems ecu in the uk. Paying £80 for postage everytime is getting real old, real quick. Thanks in advance.
          What, VEMS ECUs break? I had the impression from another thread that they were invincible.
          • QuattroFever
            • May 2006
            • 1360
            Can get a return flight for £90
            Was considering a short holiday. but turn around would be a few days.
            Id feel safer it going to manufacturer but seems crazy to spend so much money to fit a 4 euro chip.
            Volcano ABY coupe
            Ant
            • QuattroFever
              • May 2006
              • 1360
              They are until someone puts p259 ch6 to ground instead of analog ch6!
              Volcano ABY coupe
              Ant
              • A80Avant
                • 10873
                • Country: Greece
                As usual from the past few weeks, you get the wrong impressions on a few things... Probably a viral infection of some sort. Dont worry, it will pass
                There is a tuner that does vems in the UK called Gunnar Reynson and he has the nickname 'gunni' on vems forum. He may be able to help. Text him on the forum!
                • Mark.se
                  • Feb 2007
                  • 131
                  • Home: England Current: Sweden
                  You could try Camco in Warrington, I've found them helpful in the past.
                  2007 A4 2.0TS quattro (220)
                  1995 AAN powered 80 quattro (MTM Stage 2, MTM hybrid turbo, MTM ecu, Forge DV, 034 Highoutput Coil Pack Conversion, Wagner Tuning EM, 3" turbo back SS exhaust system, race cat + other bits and pieces)
                    Gunni is uk based? I never knew
                    • A80Avant
                      • 10873
                      • Country: Greece
                      Yup. Much closer to you as well!
                        I will have to check this out, cheers
                        • prj
                          • Mar 2010
                          • 6308
                          Happens more often than you might think
                          Usually due to bad wiring. Factory ECU is just much more resistant to all kinds of stupidities.
                          • Billman
                            • 4129
                            I seriously doubt that :-p
                            Go Holset or Go RS4
