I have installed a boost gauge on to the S2, and mounted it into the centre air vent. All the controls still work perfectly aswell
. On tickover i get 0.5-0.6 bar vacume which seems ok. When i put my foot down i get when not fully up to temperature about 0.7-0.8 bar, once warm it occasionally hits 0.9 bar but i am not getting any over boost. I think my manifold isnt in the bestest condition, but all the studs are new so should come out if needed. I only fitted it 4 month ago. But other things i can see related are the WGFV and the WG diaphragm. The TBV is new and is all the hoses and the Mark H intercooler mod is donecould it be anything else????
Graham
. On tickover i get 0.5-0.6 bar vacume which seems ok. When i put my foot down i get when not fully up to temperature about 0.7-0.8 bar, once warm it occasionally hits 0.9 bar but i am not getting any over boost. I think my manifold isnt in the bestest condition, but all the studs are new so should come out if needed. I only fitted it 4 month ago. But other things i can see related are the WGFV and the WG diaphragm. The TBV is new and is all the hoses and the Mark H intercooler mod is donecould it be anything else????Cheers
Graham
is the figure 0.5-0.6 bar for an aby as mine is an aby?. Also i have just changed the lambda probe to try and cure this problem to no effect, it runs a little better but not massively better.
