NPT oil inlet to turbo,what to use?
  • Lighthouse
    • Jul 2007
    • 229
    • Country: Norway
    Right..here goes! This can be funny, but i'll try and sort it out using basic english
    On my new Precision turbo there is 1/8NPT threads to the oil inlet..Usually I would use thread tape or Loctite 577 IF it not was fitted in a hot area.. SO, what should I use when I am fitting the oil inlet fitting?
    '10 A5 Coupè 2.0TFSI REVO
    90 quattro
    X- 91 S2 Coupè 467hp, 670nm!
  • madpugger
    • Sep 2007
    • 1901
    You can get high temperature liquid PTFE, however, I just used PTFE tape, as although the exhaust gasses are hot, the water should keep the body cool enough.
    Le Mans 2012
    Nurburgring 700
    1995 S2 Avant
    • Lighthouse
      • Jul 2007
      • 229
      • Country: Norway
      I do not have a water inlet on my turbo but have you spotted any leaks on your turbo?
      90 quattro
      • madpugger
        • Sep 2007
        • 1901
        There were on the water side, which is why I then used thread tape!
        Not used it enough yet to comment sorry.
        Le Mans 2012
        Nurburgring 700
        1995 S2 Avant
        • Lighthouse
          • Jul 2007
          • 229
          • Country: Norway
          Ordered a fitting from KRB Trading and found some Loctite to use
          90 quattro
          • terrybullwon
            • Mar 2006
            • 8782
            Yes theres a special loctite to use, i have used it alot
            Chef
            • quattro84
              • Mar 2006
              • 947
              So, what number did you use? Every 500-series loctite is rated up to 150 degrees C, except for Loctite 582 which goes to 200 degrees.
              • Lighthouse
                • Jul 2007
                • 229
                • Country: Norway
                We had some at work, but I dont remember what number it was.
                90 quattro
