ignition wires,6000k or 1000K
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    do you know if is it possible to use the oem 3B spark plug wires,they are 6000K,using it with high output coils that they uses originally spark plug wires with 1000K??
    is it possible? or is it dangerous?
  • M_GORDON
    • Oct 2008
    • 1295
    • Home: Isle of Man Current: Vatican City State
    K Ohms?
    If you say it. The response is NOT!
    photobucket SUCKS
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      Originally posted by M_GORDON
      K Ohms?
      yes ohms
      and explain why not?
      we have saw that the most of audi wires works with 5000K .... and after all,they are coils....and thy need some good wires,but of course i would like to know if someone knows something about it
      thanks¡
      • M_GORDON
        • Oct 2008
        • 1295
        If the new sparks work fine with 1Mohm and you plug a wire with 5MOhm more, you will have low tension and the engine not work fine.
        photobucket SUCKS
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          will check the spark plugs inside the engine,but this has a easy and cheap solution... because i can swap mines from my coupe, the Bosch f5dpor
          in the competition i dont know wich type of sparks plugs has,but the spark plug wires that comes from the coils are 1000K
