electrical sensor problems
  • QuattroFever
    • May 2006
    • 1360
    tearing my hair out at the moment....Electrics are really not my thing and I have what feels like the mother of all tasks to do to put my car right.
    with vems I wired p259 ch6 (12v output) to ground instead of analog ch6 (input) whilst trying to install a launch control switch. I know........
    I have sent the ecu to hungary for repair and its been replaced with a new unit so it's not the ecu...I should be so lucky.
    I'm taking a wild guess that this has burnt out a trace or wire somewhere and has maybe broken ground to a few sensors but not 100% on that, my electrical knowledge is very limited.
    CLT reads -40 (assumed open)
    MAT reads -40 (assumed open)
    dash rpm doesn't work
    Low oil pressure light flashing
    and sounds like running on 4\5 cylinders
    any ideas where there may be a smaller than usual trace or wire that may have blown\burnt out that is common to all these things?
    Thanks in advance electrical guru's
    Volcano ABY coupe
    Ant
  • QuattroFever
    • May 2006
    • 1360
    after digging around and jabbing with a multimeter
    turned out running on 3/5
    Which was a bad contact on a POS
    Dodgy vems EC36 connector with a few intermittent pins.
    one toasted mat sensor too...my fault.
    Volcano ABY coupe
    Ant
      turned out running on 3/5 Which was a bad contact on a POS Dodgy vems EC36 connector with a few intermittent pins. one toasted mat sensor too...my fault.
      I suspect that we will see more people hiding under chairs in the future as they find out that working with VEMS is not for the untrained.
      I say leave the tuning to the professionals. If they screw up, they have to replace the parts that they killed.
      • QuattroFever
        • May 2006
        • 1360
        You dont need to be untrained to short something. **It happens.
        Leave it to the professionals? Where's the fun in that?
        Im too nosey. I like to know whats going on.
        Volcano ABY coupe
        Ant
