You get a little tool called VAG-COM or alternatively VCDS (they were forced to rename it), and install it on your laptop.
You can have VAG-COM 409 cables off ebay for 5$ and you also need something called a "2x2 adapter".
Get one, it will be more than enough for you, and it's cheaper than driving somewhere, never mind paying a garage to do the diagnostics.
I have an RS2 MAF on my RS2'd AAN and would not switch back (unless the RS2 MAF broke).
