Isn't a "shagged" WG spring in the same category as "wastegate chatter", hobgoblins and other mythology ?
Seen plenty of torn WG diaphragms and yes the valve itself is not completely air tight. The latter worsens with age thru wear. It would be great to agree a simple test on the WG that determines if it is leaking ok or leaking too much.
Ages ago I played with an rs2 WG and an airline to try and get a measure of when it opened. I think I videod it too - will take ages to find results and such. Might have to do it again.
