2.5l conversion
  • Firebird69
    • Aug 2010
    • 83
    2.5l conversion
    Anyone drive a 2.5l conversion in an 2.2 S2- or UrS Block? (AAN, ADU, ABY, 3B).
    I plan to build an engine like that...can I use a 2.5l diesel crank out of an Audi 100 or Volvo or do I need a race-crank...I think they are pretty much to same?
    what is your experience?
    are there any threads on here about that which I just didin't see
  • Rusty
    • 18953
    There are quite a few stroker threads. Start with RWD19T's, Jamo's and AndyP's and I'm sure yo'll find plenty of links from there. Crank is diesel for 95.5mm, race for higher, you'll also need to decide whether to use the OE block or diesel block and that will affect most of the rest of the build... until you get to turbo choice and then mapping... it's a nice dream and most on here will have had it at some point but it usually stays in the 'if I won the lottery' part of the brain. Good luck if you do go down that road, I'm sure it'll be fun
      The 2 must read threads are:
      Then you have mine, AndyP, RWD19T, Audi_CQ there are a load of them on here.
      • Firebird69
        • Aug 2010
        • 83
        thanks a lot Rusty...the thing is mostly I'm woundering if it is a good Idea to use the nice AAN that I already have??
          Using AAN 220mm block? It can be done things to be aware are high piston ring wear rate, steep rod angles and short compression height required on the pistons
          If you can source a 92.8mm crank that is the best route for 2.5/2.6 l in the AAN block
          • Firebird69
            • Aug 2010
            • 83
            thaaaaaaank you so much...
            • Firebird69
              • Aug 2010
              • 83
              Thanks Jamo...I already got JE-pistens reg. compression for my AAN 81.5mm bore. Do you think I should get diffenert pistonsrings for them or use original? Pistons should work I believe......... so finding a 92.8mm crank and some good rods are the mission now I suppose? and get a stiffener plate for the block...
                You need custom pistons for either setup you cant use OEM pistons, some claim you can but the CR is too high
                • Firebird69
                  • Aug 2010
                  • 83
                  hm...ok...I need to talk to my mechenic about that...so your saying lowering the compression with the head gaskat could not get low enough?
                    That's going to be a big gasket
                    • Firebird69
                      • Aug 2010
                      • 83
                      oh...you are right...I was planning on using shorter rods as well
                      • Billman
                        • 4129
                        about stock pistons and diesel block and crank
                        Go Holset or Go RS4
                          He's not using a diesel block, he want to use the AAN block
                          • Billman
                            • 4129
                            aha! Then Jamo is right. This engine will not live very long.
                            Go Holset or Go RS4
                            • caterpillar
                              • 2480
                              92,8 crank are NOT so commen in audi cars... but in some eurovans with 2,5 l 10v petrol; the may have this item; not always...in some 4pot audis you have this in some audi 80 fx... but the crank doesnt fit 5 pot....8-))
