I've just got around to fitting my FMIC for the urs4 and realised that there's an issue with clearance on the power steering coolant pipes
. My friend, who's helped with the installation of the FMIC thinks that we can do without the coolant pipes, I think that Audi must have put the coolant pipes on the car for a reason as the coolant presumably gets very hot.
Is it healthy for the life of the pump/fluid to do a coolant pipe "delete" or should I relocate the pipes as seen in this Audifans thread?
The clearances don't seem quite the same on my urs4 as on the pictures in the thread although there is room for fiddling.
thanks for any advice.
. My friend, who's helped with the installation of the FMIC thinks that we can do without the coolant pipes, I think that Audi must have put the coolant pipes on the car for a reason as the coolant presumably gets very hot. Is it healthy for the life of the pump/fluid to do a coolant pipe "delete" or should I relocate the pipes as seen in this Audifans thread?
