need help for 5 cylinder engine 2.3 lt.
  • fatiii
    • Nov 2010
    • 130
    • Country: Turkey
    hi all i ask a quastion,my sleeves between are 5mm.i think to use 034 motorsports copper head gasket..now let's question this distance create any problems?(burn the gaskets vs.)
    my idea going to sc6262 35 psi...Waiting for friends who experienced comments..thanks for answers and sorry my english..
    this block is not mine it's representation
    Uploaded with ImageShack.us
    What bore are you running? That will help people answer your question.
    • fatiii
      • Nov 2010
      • 130
      • Country: Turkey
      sorry i forgot 82.75 mm
      • caterpillar
        • 2480
        if the gasket are in the combustion chamber, they WILL burn out, due the use...then you will have the leak and bad engine... some use the 83,00 gaskets..
        • fatiii
          • Nov 2010
          • 130
          • Country: Turkey
          gasket bore 83 mm piston bore 82,75 so can not in the combustion chamber.
          • fatiii
            • Nov 2010
            • 130
            • Country: Turkey
            upppppp..waiting comments
            • fatiii
              • Nov 2010
              • 130
              • Country: Turkey
              Does anyone know anything?
              • fatiii
                • Nov 2010
                • 130
                • Country: Turkey
                uppppp,i need help
                • fasterthenrs2
                  • Nov 2007
                  • 275
                  • Home: Latvia Current: United States
                  Just buy a stock mls gasket and bore that to your spec
                  DD 1990 CQT 800+HP SOLD
                  1/4 mile 10.70@135.66
                  (SOLD)
                  http://www.youtube.com/watch?v=Yy-YlssmSfY
                  http://www.youtube.com/watch?v=8XgzVJyvrfg
                  2003 A6 4.2 Quattro
                  97 MB S320 DD
                  • JP
                    • 1858
                    First of all let's look at headgaskets.
                    Stock 20v turbo MLS = 82mm bore
                    Stock 7A Fibre = 83.5mm bore
                    Next engine bore size
                    Stock 20v turbo = 81mm bore
                    Stock 7A = 82.5mm bore
                    Conclusion if you wish to run larger than 82mm you should either run a copper gasket or a fibre gasket. In both cases you need to o-ring the block to prevent gasket failure.
                    Personal opinion is don't run more than an 82mm bore if going FI for ease and reliability. Also the larger the diameter the piston the more susceptible you are to rapid small end bush wear especially if running aftermarket rods without rifle drilling for direct oil pressure feed.
                    Now this means either you junk the 7A block and source a 20v turbo one or you fit sleeves to the 7A. Either way there is not much difference in cost by the time you pay for the more expensive copper gasket and o-ringing procedure.
                    Hth JP
                    UrS6 Stroker + HTA3586 =
                    • JP
                      • 1858
                      *sorry forgot to mention if you overbore a stock MLS gasket you will end up machining the fire ring which helps seal the combustion gases. Without the firing ring you may aswell stick in a copper gasket without o-ringing they'll both be as useless as each other.
