I had a problem with an MB last week, and it's started me wondering about the suitability of Magnecor ignition leads.
See http://www.magnecor.com/magnecor1/7mm8mm.htm
This clearly documents a linear resistance of 3k Ohms/foot.
Audi's specification for the 10V I5 plug leads is 5k Ohm in the plug cap, close to zero in the lead, and 1k Ohm in the distributor plug for a total of 6k Ohm. And true to what you'd then expect, a new set of Audi leads measures out at close to 6k Ohm on each lead, irrespective of length. #1 and #5 are therefore the same.
Not so with a set of Magnecor leads purchased fully made up as a replacement (supposedly an 'improvement') for Audi stock leads. #1 measures as just over 6k Ohm, #5 as under 3k Ohm. That's exactly what you would expect if the plug cap and distributor plug had zero resistance and the Magnecor lead was 3k Ohm/foot.
I think having one plug lead with twice the resistance of another can only lead to problems.
