Beta Test: DIY Replacement of 7A, 3B and early AAN Hall Sender
    I needed a break from house projects so I decided to do this. Open to constructive criticism and suggestions before I finalize.
    Now June 2, 2011. Revised final version is posted further down in the thread.
  • orangepeel
    • Feb 2011
    • 205
    thanks for that bit of info will cum in handy if i have to do mine cheers
    • Thuppu
      • 4115
      That sounded funny.
      • mcandmar
        • Apr 2004
        • 5118
        Nice guide, but needs a quick amendment. The 7A dizzy should have a plastic cover the same as the AAN, its just mine got a little chewed up. Tie wraps are definitely not OE
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
          Thanks. I will make note of that for the final version.
          EDIT: Change made. Thanks for that.
          • orangepeel
            • Feb 2011
            • 205
            doh!!!! just notist
              Originally posted by orangepeel
              doh!!!! just notist
              Hey guys, stay on topic.
              • caterpillar
                • 2480
                in the 10v 5pot; I have done this job in my 32b (!!!!!) same as audi 80/90/some urQ and others. BUT i have used gm (opel 4pot) dizzy. why? because the org audi /vw part may have some wear at the leads, and have major breakdown in the ignitions.. gm have the dizzy filled with epoxi over the leads...; remember the elektric connektor in the side of distrubitor are made sa a key,so you need the correckt part for the car you have...
                then i have a singel coil for 5 pot,, the crane ps91 .. and 1,2mm gap in sparkplugs.
                  So we're done with comments and I can finalize this?
                    Revised 7A, 3B and early AAN Hall Sender R&R DIY
                    Someone *might* be happy to find this at some point in the future.
                    See attachment list below.
                    Also available at:
