There's always a trade-off between what's best and what you have space for. As long as it's no smaller than the inlet to the turbo and the taper is smooth to 80mm, like a Samco hose for example, and the section of smaller hose is minimal, IMO you'll be fine. The tubular EM is what's killing you there; a Wagner Evo would provide a lot more space for proper intake plumbing with cold air feed etc. You'll also need to make space for a brace to go from the turbo to the rocker cover, to prevent the EM from being overly stressed.
Yep, Chinese made for sure. Why would they make 99% chinese look like in USA?
