ABY Braided fuel line
  • Chris P
    • Dec 2004
    • 145
    Can anyone confirm if the braided steel fuel line in the engine bay on an ABY engine that goes from the fuel pressure regulator, has the same female thread size on the other end (the end that fixes to the fixed solid line in the engine bay) as on a 3B engine. I know the AAN line doesn't but have read somewhere that if using the AAN fuel rail in the 3B engine, you need to use the ABY line.
