rs2 not pulling hard enough
    Think you have fresh hoses - so leak maybe intercooler or TBV.
    The other possibility is that N75/Wgfv is leaky or not modulating fast enough. Is it a fresh one ?
    Is the TbV plumbed in right way round ?
    • dobbin
      • Jan 2011
      • 164
      yes all new hoses ,found small leak fron n75 which is new ,replaced new jubilee clips with proper crimp rings. can u show me a pic of tbv or diagram correct way around. will test tonight to see if boost is better than 1.55 at 4000.
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        Can be the vag-com downloaded?
        • dobbin
          • Jan 2011
          • 164
          stripped front end of car pressure tested hoses , blocked off before throttle body no leaks but can hear oil bubbling . pressure tested intake manifold blocked off pipes to ecu found a large air leak only after 1.3 psi from hose under throttle body next to fuel pressure regulator . changed clip retested up to 2 psi no leaks . once i put front bumper back on tomorrow will let you know how i get on
          • jade
            • Jan 2005
            • 1811
            #20
            No fuel pressure regulator under throttle body !
            RS 2 580HP
            • Golfboy666GTI
              • Sep 2008
              • 571
              • Country: New Zealand
              #21
              How did you get on?
              1980 VW Golf GTI Track Car
              1995 Audi RS2
              • UrS6 - IamS6
                • Nov 2014
                • 148
                • Home: Ireland Current: Western Sahara
                #22
                Dobbin, how did this pan out, just curious ?
                Thanks.
                • dobbin
                  • Jan 2011
                  • 164
                  rebuilt the head and all valves reseated and new seals and all new studs after finding stud broke on rear of exhaust manifold decided to rebuild turbo to hybrid took car to mrc and had it remapped and 630cc injectors fitted.
                  explained to mrc about boost issues all ran ok for them for one week and 400hp result.
                  got car home after one day holding back on boost again 1.4 should be 1.7 . back to mrc who changed both pos units ran car for a week all ok .
                  picked car up 18th dec perfect for 100 miles coming home and back to how it was again.
                  removed altitude sensor on pins 1 and 2 should see 1200ohm , only seeing 460ohm tried to adjust back to 1200 ohm boost came back for 20min drive and back to 490ohm, So have just ordered a new sensor 5 days from Germany and then hopefully job done . to be honest lots of little faults causing problems that's what you get
                  for having 20 year old car . thank god for the S2FORUM and a lot of patience
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Think we all the know the feeling well, surprised you haven't done the coil conversion though
                      F96 Altitude/Barometric Pressure Sensor Information
                      ...picked car up 18th dec perfect for 100 miles coming home and back to how it was again.
                      F96 Altitude/Barometric Pressure Sensor Information including testing and GandalfS6's DIY on adjustment:
                      • UrS6 - IamS6
                        • Nov 2014
                        • 148
                        #26
                        Dobbin, thanks very much for an in-depth reply.
                        Best of luck with it, maybe post the results on here until the car is perfect / stays perfect. Hopefully it's short thread.
