GT3076 .82ar + Cat Cam 1002305
  • |CL|NIKI
    • Jun 2008
    • 380
    • Home: Bulgaria Current: United Kingdom
    Is anyone tried that combination of 2.2l 5 cyl. Engine - AAN - GT3076 .82 hot + Cat Cams 1002305?
    The engine has stock pistons, stock head - no porting or big valves, orig. camshafts 630cc injectors, forged connecting rods and is now 500hp.
    What would be achieved by replacing the original camshafts with Cat Cams 1002305? Will increase torque and / or horsepower or turbocharger starts earlier or make it worse?
    800HP 800++Nm
  • |CL|NIKI
    • Jun 2008
    • 380
    I just found that the turbo will spool early about 700-800rpm...
    800HP 800++Nm
    • caterpillar
      • 2480
      bigger exos too,no cat.....???
      • caterpillar
        • 2480
        and chipped or?
        • |CL|NIKI
          • Jun 2008
          • 380
          Stock valves, no ported head. And Yes - re-maping again...
          800HP 800++Nm
          • |CL|NIKI
            • Jun 2008
            • 380
            300kW on the wheels.
            800HP 800++Nm
            • A80Avant
              • 10873
              • Country: Greece
              Is that with the cam in place?
              that is roughly 400whp, so again depending on the dyno, around 500hp.
              can you also give me some details of the spool with the 3076 that you have? for example, what boost are you reaching at 3d or 4th gear at what rpm and what is the difference before and after tha cat cams?
                Hmm got anything to back that up?
                • dkw_dude
                  • 555
                  • Country: Norway
                  x2, boost before/after @3000, 3500, 4000, 4500
                  Leif-Helge
                  -91 S2 VEMS and Comp Turbo
                  -12 B** 530XD Touring "S2 parts transporter, and daily driver"
                  • zlobo
                    • 967
                    i got 437whp with the gtbb3076 with 7a camms @1,5bar of boost full boost at about 4000rpm
                    ABT C5 Lord Of The Rings
                    2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
                    2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
                    2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
                    kostic.nu
                    • A80Avant
                      • 10873
                      • Country: Greece
                      Full boost at which gear?
                      And which type of dyno? Do you have any performance box logs?
                      sent using Android
                      • zlobo
                        • 967
                        on rototest no logs from any boxes best et with this power is 11,45 and 213km/h
                        edit: it's maped on E85 ported head stok valves je pistons peter-g em 3,5" downpipe 3" exhaust, verdi rods,
                        kostic.nu
                        • A80Avant
                          • 10873
                          • Country: Greece
                          On rototest you get about 15% addition for losses, so that makes it +/- 500hp crank. Not bad for 1.5bar boost!
                          sent using Android
